the dutch guy wrote:If you rotate 1 wheel the other wheel should go in the opposite direction, that is how the diff works. But usually you only see this with rear wheel drive and a locked gearbox (in gear, engine off).
grogan197 wrote:the dutch guy wrote:If you rotate 1 wheel the other wheel should go in the opposite direction, that is how the diff works. But usually you only see this with rear wheel drive and a locked gearbox (in gear, engine off).
Yeah, that's what I was expecting one to go clockwise and for the other to turn anti-clockwise. They both turn clockwise now though
the dutch guy wrote:that means the diff is probably not happy. my guess is that one of the little gears has locked up the diff and/or skips teeth. driving at this point (putting real power on the gears) would probably break the gearbox apart.
please tell me you have rear wheel drive and can simply service the diff and not have to take the gearbox to bits...
the dutch guy wrote:set it down and move it back and forward a bit and listen for crunchy noises. if you dont hear anything then make a sharp turn SLOWLY and listen for noises.
grogan197 wrote:the dutch guy wrote:set it down and move it back and forward a bit and listen for crunchy noises. if you dont hear anything then make a sharp turn SLOWLY and listen for noises.
Thanks. By moving it do you mean trying to drive it, or by pushing it in gear?
the dutch guy wrote:grogan197 wrote:the dutch guy wrote:set it down and move it back and forward a bit and listen for crunchy noises. if you dont hear anything then make a sharp turn SLOWLY and listen for noises.
good luck pushing in gear.
just drive it and use a feather on the clutch. and listen carefully for any un-transit-like noises from the drivetrain. if you hear any crunching and stop immiedialy and prepare for a gearbox replacement.
