davireland wrote:Ok guys thanks for your help , have found the problem , it was indeed the loom , a previous owner must have had a problem or a need to access the wiring , the protective casing had been slit open and taped back together and it was rubbing on the side of the junction box, as soon as I moved the loom the problem disappeared , may have to look at replacing that front loom, thanks again.
