the dutch guy wrote:wheel size does extremely little for ride height. if you want to keep the van below 2 meters you need to drop the springs at the back. you can win 5~7cm easy as the front is lower to begin with.
normal SWB is between 197 and 205cm at the rear with a empty cargo bay and normal sized tires. the front is ~190cm.
DickP wrote:Thanks The Dutch Guy, so what are the standard tyre sizes?
I have seen the SWB with small tyres and others with big. Are the bigger ones put on by the owner then?
bigjohnthomas wrote:Its on the weight my boy
less than 300 has 15s and above 16s
Unless its a limited then its got 16 inch alloys init
The discs are bigger over 300 so girly little 15s won't fit over the calipers
bigjohnthomas wrote:You might say that but....
When I swapped from 15s to 16 " alloys on my mk 7 it made no difference to fuel used at all
One sometimes forgets that a transit is a 2 tonne blob with the aerodynamics of a gable end
A bit more rubber on the road makes little difference
