grogan197 wrote:I've got and have activated the Ford Extended Programming hack that gives a 120 day extension to module programming. Is that what you mean or is there something else I don't know about?
ake wrote:Unless you buy a genuine VCM2 for around £2k and pay the annual subscription to Ford for ids, they are all going to be fake.
knobby1 wrote:Go for the ELM327 like this:
http://www.ebay.com.au/itm/USB-Modified ... 2749.l2649
Then download Forscan for PC..(it's Free)...and you should be good to go...
I also have an IDS system which does work and I've been an advocate of using it for quite some time... but it was a right ball-ache to get running properly, took me a couple of weeks and help from Loot on here to get me up and running...Thanks mate..!
I bought the above USB ELM327 a few weeks ago, downloaded Forscan from the interweb...and it just works, simple as that..
CDPDesign wrote:What access does this give you though? Can you recode items or is it just a fault code reader?
Users browsing this forum: grego
