fitzy wrote:Can you program modules using the Forscan software, like the PCM for example?
Dave
Yes..!
Dave
knobby1 wrote:fitzy wrote:Can you program modules using the Forscan software, like the PCM for example?
Dave
Yes..!
loot wrote:Forscan is basically a software (coupled with a modified elm 327 obd tool) which seems to have nearly full access to Ford module/data, the program is based on pids and backwards engineered coding that reads/modifies/writes to the modules, it is continuously being tested and developed so new functions/vehicles are continuously being added.
I've tasted this when i was modifying the transit software to turn on certain functions, so i know how much time and effort go into it
Again it takes all this time because they have to stay away from copywrite infringement and because Ford/bosch/visteon etc don't give out any info to 3rd parties (and tbh quite rightly so!)
Note tho, as yet I've not seen any evidence that there is any software able to bypass the new etis coded security function @ 2012 adding keys/modules online
This includes clone ids and forscan.
Also ids is less code related and has specific functions and it clearly explains to you what the procedure you are about to perform is.
Fordcan i found to be slightly more code related and while some ppl prefer forscan, i prefer ids.
However, forscan is free (requires a modified elm 327 adapter) about 15 gbp so for that you can't go wrong
Ids is designed specifically but it is about 100gbp+and requires installing which some ppl struggle with and also there are so many varying quality vcm2s floating about and some are faulty.
I have both and use ids, been on forscan once.
I recommend forscan tho as it does code reading etc that is the most common use you'll have for it, module reprogramming etc tbh I'd be a bit worried about forscan because it seems too open source for me and i don't believe it has all the security protocols in place, it looks like a page of writing but with spelling mistakes in places to me, that's in a coding point of view tho. Incomplete and insecure.
I've fooked things up on ids plenty of times but always recovered it, from power interrupts and programming errors and so on.
Had 1 go on forscan but felt prickly heat on my neck Lol
Not sure why i wrote all that, it isn't a specific endorsement or anything just my thoughts on it, see a lot of ppl who can't decide or not sure what each software is and stuff.
Bloody Ford
grogan197 wrote:I'm sitting here with my second fake VXDIAG VCX Nano. This time I went for one being sold at a higher price and the listing even said tested with PCM programming which it obviously wasn't.
Both my scanners work for code reading and live data but any module programming they just throw errors. The one I got a month a go looks like it's going to work then throws an error code. The one I got today just says vehicle battery too low, I hooked the van to a charger and still the same. Looking at the details it's only picking up 6v at the obd port. The other tool shows 12.7v so it would seem that's where the problem lies with the second fake.
Can anyone recommend a seller of a decent VCX Nano or VCM II that will work with module programming? Failing that does anyone have IDS near Rugby/Coventry who I could pay to update the ECU's on a couple of vans?
twin--turbo wrote:Forscan won't do software updates on modules.
Even got forscan running natively on Linux, although it does not run the extended licence.
TT
twin--turbo wrote:"Programming" or actual software updates?
grogan197 wrote:ake wrote:Unless you buy a genuine VCM2 for around £2k and pay the annual subscription to Ford for ids, they are all going to be fake.
Yeah I understand that they are essentially all a knock off of the ford vcm2. There seems to be plenty of members with good clones though and I've heard the ones that are made by VXDIAG are good if genuine and likewise the VCM2 clones can be good. Problem is the Chinese copying the copies and losing some functionality along the way.
I successfully updated the pcm on an Mk7 with an out-of-the-box vcx nano (the WiFi version running IDs 107 on a VM).slugmeister wrote:grogan197 wrote:ake wrote:Unless you buy a genuine VCM2 for around £2k and pay the annual subscription to Ford for ids, they are all going to be fake.
Before you throw out those VCX Nanos are you aware of the need to program the FEPS voltage? Out of the box it appears the VCX NANO don't provide the 18V FEPS voltage on pin 13, but they can be manually programmed to do so.
I tested that on my VCX NANO and it works, after doing the mod the VCX now provides the correct necessary FEPS voltage but Im too cautious to have a crack at mine yet because I have an unrelated issue with the map on my PCM.
I will be testing a bench programming of an ECU later this week using a donor 1C1AND PCM same as mine with the same map, so I will let you know if it all works...
Users browsing this forum: Bing [Bot], Google [Bot]
