Dreaded mk6 speedo fault
Re: Dreaded mk6 speedo fault
Postby daz1412 » Mon Sep 18, 2017 9:59 pm
Sadly I can't rework it. the ones I need have no cables in them I'll try strip the old cables out and re do it, failing that could i just loop the cables at the loom end where needed?
Again, cheers for the help everyone. really appreciate it. One of the best forums i've used.
daz1412
Postby daz1412 » Mon Sep 18, 2017 10:30 pm
I've already cut two of the wires to attempt a rearrange but it never worked. Mine was wired as is seen below.
daz1412
Postby APH » Mon Sep 18, 2017 10:42 pm
you can re use that, if you release the locking tabs the terminals will slide out and you can put them back where they should be, solder wires together, or crimp them and it should work, however, you can easily work out the wires on the other side of the loom to join together too if you don't want to use he plug, as you can see the positions of the two link wires in that other picture you posted. so can look at what colours they correspond too on the main van wiring harness.
Andy :D
(\__/)
(")_(")
this is bunny
APH
Postby APH » Mon Sep 18, 2017 11:21 pm
On the van loom, join white/green to white/violet, and join yellow to blue
Andy :D
(\__/)
(")_(")
this is bunny
APH
Postby daz1412 » Tue Sep 19, 2017 3:46 pm
Scrap that. It's working, realised I had removed the fuse the other day. I have a speedo! Reverse switch - check. Speedo - check. Now to get the welding done. Thank you very much for the help chaps.
daz1412
Postby andz327 » Tue Sep 19, 2017 8:44 pm
daz1412 wrote:Is this the reverse switch? Seems to be one bolt but still isn't loose after removing said bolt.
That picture looks like a crankshaft sensor mate
andz327
Postby ned » Tue Sep 19, 2017 9:01 pm
daz1412 wrote:Scrap that. It's working, realised I had removed the fuse the other day. I have a speedo! Reverse switch - check. Speedo - check. Now to get the welding done. Thank you very much for the help chaps.
Was it the bridge on the tacho wiring that got it working again (and the fuse)?. N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby daz1412 » Thu Sep 21, 2017 3:22 pm
Yep, the bridge sorted it. feel like a bit of a tit having traced wires here there and everywhere. the main thing is it's sorted. Will make it a lot easier to sell when the time comes.
Thanks chaps!
daz1412
Postby Really Good Idea » Tue Sep 26, 2017 9:54 pm
daz1412 wrote:Yep, the bridge sorted it. feel like a bit of a tit having traced wires here there and everywhere. the main thing is it's sorted. Will make it a lot easier to sell when the time comes.
Thanks chaps!
So how did you fix this?
I've still got the same problem after soldering and not sure what I should be checking next :/
Here is a picture of some loose connectors behind the instrument panel
Here are FOUR different loose connectors by the passenger side fuse box
Any hints as to where any of these should go?
Please help me fix up my van into a camper!
Transit 06 90 T350 TDDi - LWB High Top, one green door
Really Good Idea
Postby Really Good Idea » Wed Oct 04, 2017 11:20 am
Any help?
Really Good Idea
