vaccum pipes
vaccum pipes
Postby stiggy17 » Wed Sep 13, 2017 1:01 pm
Any 1 got a diagram for vaccum pipes on a ford transit tourneo 04 plate? or no were i can get 1? last owner took all engine apart so i dont no if they are back in right order
stiggy17
Re: vaccum pipes
Postby wojciech » Wed Sep 13, 2017 3:16 pm
stiggy17 wrote:Any 1 got a diagram for vaccum pipes on a ford transit tourneo 04 plate? or no were i can get 1? last owner took all engine apart so i dont no if they are back in right order
Is it tdci ot tddi?
For tdci: posting.php?mode=quote&f=5&p=1255987
wojciech wrote:
v8dave wrote:IVacuum pump will be in the same location for any 2.4 rwd :)
Danniboy is looking for vacuum control system for VGT turbo (it is tdci) and EGR valve.
O.k. - I went to my Mk6 2,0 tdci, it is the same injection system as in Mk6 2,4 tdci and I looked for vacu pipes.
I think - it is big chance, you have exactly the same vacu system.
Are two vacu electrovalves. First has green electric plug and works for VGT turbo, second has black electric plug and works for EGR. It is impossible to exchange both plugs on wrong place.
Both electrovalves are looking identically, every one has three connection terminals for vacu pipes.
Vacu pipe from central terminal on valve with green plug, is connected to turbo servo.
Vacu pipe from central terminal on valve with black plug, is connected to EGR servo. This pipe is black with white stripe.
Outside terminals are connected together to vacu pump and to vacu bunker under weendscreen. Once I had broken pipe going to bunker and engine was very poor.
Opposite terminals on valves are also connected together to air filter.
Its all.
Its all about engine pipes, second problem are vacu pipes for heater & air conditioning controls.
wojciech
Re: vaccum pipes
Postby stiggy17 » Wed Sep 13, 2017 10:27 pm
2.0 TDCI
stiggy17
Re: vaccum pipes
Postby ned » Wed Sep 13, 2017 10:55 pm
I can have a look at mine after work tomorrow and take some pictures if it helps. N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Re: vaccum pipes
Postby stiggy17 » Wed Sep 13, 2017 11:59 pm
ok. thanks
stiggy17
Re: vaccum pipes
Postby ned » Sat Sep 16, 2017 3:52 pm
The one with the white strip goes to the egr,
The top solenoid is the turbo,
The bottom solenoid is the egr,
Not the best pictures but I'll try and get some better ones. N
ned
Re: vaccum pipes
Postby ned » Mon Sep 18, 2017 7:52 am
ned
Re: vaccum pipes
Postby stiggy17 » Tue Dec 12, 2017 12:11 am
hi mate,
were does this pipe go to ?
stiggy17
Re: vaccum pipes
Postby ned » Tue Dec 12, 2017 8:50 pm
It disappears into the bulkhead/firewall I think, I'm not sure if it goes to the heater. N
ned
Re: vaccum pipes
Postby stiggy17 » Wed Dec 13, 2017 12:00 am
thanks
sorry to be a pain
but do you no what pipe goes on this ?
stiggy17
Re: vaccum pipes
Postby ned » Wed Dec 13, 2017 12:05 am
What's the pipe its coming off for? Without looking at my van I couldn't tell you, I can have a look tomorrow when its light. N
ned
Re: vaccum pipes
Postby stiggy17 » Wed Dec 13, 2017 12:54 am
it comes off the back of the vaccum pump
stiggy17
Re: vaccum pipes
Postby ned » Wed Dec 13, 2017 1:09 am
I'll have a look tomorrow but if it comes off the vac pump I think it T's into the egr vac pipe. N
ned
Re: vaccum pipes
Postby stiggy17 » Fri Dec 15, 2017 12:08 am
ok thanks
stiggy17
Re: vaccum pipes
Postby stiggy17 » Sat Dec 16, 2017 8:58 pm
did you have a look what goes there mate
stiggy17
