t2myd wrote:No different box
RECKLESS ROAD wrote:I have a 2008 2.4 camper and I need to change the gearbox , I've seen one for sale but it's from a 2012 rwd which was the 2.2 engine , will it fit ?
RECKLESS ROAD wrote:ive got a 6 speed rwd box now for 2.4 with the cables and gear lever and ive got the prop shaft too , do I need to change the clutch and flywheel ? and is there anything else I need ? , changing from a 5 speed to a 6 speed
I got a prop shaft off a 6 speedknobby1 wrote:RECKLESS ROAD wrote:ive got a 6 speed rwd box now for 2.4 with the cables and gear lever and ive got the prop shaft too , do I need to change the clutch and flywheel ? and is there anything else I need ? , changing from a 5 speed to a 6 speed
I "think" the prop shaft is a slightly different length between the 5 & 6 speed boxes, also the rear box coupling...worth checking at least..!
RECKLESS ROAD wrote:I got a prop shaft off a 6 speedknobby1 wrote:RECKLESS ROAD wrote:ive got a 6 speed rwd box now for 2.4 with the cables and gear lever and ive got the prop shaft too , do I need to change the clutch and flywheel ? and is there anything else I need ? , changing from a 5 speed to a 6 speed
RECKLESS ROAD wrote:the prop was off a mk7 lwb which is the same van as my camper and its fits the new 6 speed coupling but not the 5 speed, that all fits ok I just need to know do I need to change the clutch and flywheel to a 6 speed gearbox one or is it the same as a 5 speed clutch and flywheel
Users browsing this forum: Bsu68, Majestic-12 [Bot]
