Drum removal help please
Postby onemanpeloton » Sat Sep 16, 2017 2:15 pm
Hi all
Trying to replace some broken wheel studs on my 2006 t350 rwd.
Im trying to get the drum off but it hasnt budged. Despite reaching in through one of the stud holes to slacken off the shoe adjuster.
Do i need to remove the big central nut? Picture in the link velow
Thankyou
https://ibb.co/ePBiEQ
onemanpeloton
Re: Drum removal help please
Postby Thequeenscheese » Sat Sep 16, 2017 2:30 pm
Obv make sure your and brake is off lol, repetitive hitting with a hammer you may also be able to use a lever to help, there could be a type of hub puller on the market that would fit, but if all else fails cut it off and buy a new one I can't imagine they would be expensive tbh..
2.2 tdci T280
Thequeenscheese
Postby onemanpeloton » Sat Sep 16, 2017 2:54 pm
Thanks. But do i need to remove the 65mm nut to allow the drum to come off?
onemanpeloton
Postby Mr RVM » Sat Sep 16, 2017 5:02 pm
onemanpeloton wrote:Thanks. But do i need to remove the 65mm nut to allow the drum to come off?
No :!:
Originally Restorationvanman
Mr RVM
Postby onemanpeloton » Sat Sep 16, 2017 5:59 pm
How do i get the drum off then?
onemanpeloton
Postby bambi mk 1 » Sat Sep 16, 2017 8:11 pm
You have a 135 with a dana axle :?: :wink: You need to take the nut off .
Theres the good guys,theres the bad guys but there only ever be one SPEED GUY
bambi mk 1
Postby dumper » Sat Sep 16, 2017 9:09 pm
X2 hub and drum all one unit
Mk6 56reg 135 jumbo motorsport camper van
MK 8 L4 H3 Motorsport campervan under construction
dumper
Postby knobby1 » Sun Sep 17, 2017 8:39 pm
Yep...and they're bloody tight too...~ a million lb-ft..! :shock: You'll need a nice long 3/4" drive bar with 65mm socket, and probably a pipe extension...I'm ~90kgs & had to jump on 4ft long bar to get mine undone..!
Drivers side, (if RHD).. will be right hand thread, passenger side will be left hand thread.
Postby onemanpeloton » Mon Sep 18, 2017 9:23 am
Thanks everyone for the clarification.
I will report back and let you know how f*×%ing tight it was
onemanpeloton
Postby onemanpeloton » Mon Sep 18, 2017 12:37 pm
So ive been to the dealer this morning. Ordered 5 new studs, a new 65mm nut, a gasket for between the half shaft and drum and the oil seal that sits (i think) on the axle behind the drum.
Any other parts I need or tips for assembly?
onemanpeloton
Postby dumper » Mon Sep 18, 2017 9:05 pm
Don't put the bearings back dry I always grease them with hight melting point greases I was in my local mot garage getting vans mot they had a iveco on the ramp cutting the hub off some muppets had just put new discs and bearing on the rear dry and made a right mess of it
dumper
Postby knobby1 » Mon Sep 18, 2017 11:24 pm
dumper wrote:Don't put the bearings back dry I always grease them with hight melting point greases I was in my local mot garage getting vans mot they had a iveco on the ramp cutting the hub off some muppets had just put new discs and bearing on the rear dry and made a right mess of it
On the Mk7 RWD Dana axle, (disc brake), the bearing is "wet" and lubed by the oil in the diff housing, I suspect the Mk6 Dana is similar...but yes, as Dumper mentions, never put a bearing in dry, only takes a few revolutions when dry and with a couple of tons of weight to damage/destroy an otherwise good bearing...same with the seal running surface...give it a goodly coating of grease on the running faces when fitting the new seal, too much grease can just be a nuisance, none can be a big drama.
Postby onemanpeloton » Tue Sep 19, 2017 9:46 pm
Thanks again everyone.
All back together now and ready for a nice 300 mile trip tomorrow.
Next job is front discs and pads :-)
onemanpeloton
