by Beaker » Sun Sep 17, 2017 1:23 pm
I believe you can alter the locking sequence by re-progranning the central locking. That way you can single lock it from the inside like Dumper does in his van. My van works the same way as Dumper, so it must be possible.
I'm not sure if it can be done via the key and ignition, or if you have to do it through the OBDII port with a reader.
I'm sure someone will be able to tell you exactly how to do it.
2011 SWB medium roof 2.2l Mk7 115 T300 in Frozen White. Stealth Camper converted.
"It's better to burn out, 'cause rust never sleeps..."
