mk6 central locking fob coding
Postby smudger114 » Mon Sep 18, 2017 11:58 am
Hi all
i had a problem with my diesel pump (which is now ok(thanks everyone)) but since then my battery light stays on when ignition turn of so have disconnected the battery to recharge and since refitting the battery my key fob won't work
i've been told i can reprogram it using the ignition and the fob can anybody help with this or know the procedure to follow
thanks
smudger114
Re: mk6 central locking fob coding
Postby ned » Mon Sep 18, 2017 12:27 pm
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby smudger114 » Mon Sep 18, 2017 1:46 pm
Cheers I will try this and let you know
smudger114
Postby smudger114 » Tue Sep 19, 2017 1:47 pm
cheers this work a treat
and have sorted put the ignition light as well all runnig fine
smudger114
Postby ned » Tue Sep 19, 2017 3:39 pm
Try this for something different :wink: N
viewtopic.php?f=18&t=136854
ned
