Battery connection re split charging.
Postby DanTe » Tue Sep 19, 2017 1:36 pm
Hi everyone last time I visited I had been converting a mk7 mwb 140 to a camper, this is now complete . What I'd like to add now is my split charge kit but having the 2 battery model not sure if I should connect to front (accessories) battery or the rear (engine start) battery. Could someone please advise..
DanTe
Re: Battery connection re split charging.
Postby Cheese Monkey » Tue Sep 19, 2017 4:04 pm
If you gota split charge kit either is fine
98 Mk5 SWB MR Sold
03 Connect LWB sold
11 Mk7 350 140 Jumbo HR
Cheese Monkey
Postby Beaker » Tue Sep 19, 2017 5:51 pm
I was advised to fit it to the front battery when I did mine.
Ake told me to do it. :D
2011 SWB medium roof 2.2l Mk7 115 T300 in Frozen White. Stealth Camper converted.
"It's better to burn out, 'cause rust never sleeps..."
Beaker
Postby DanTe » Tue Sep 26, 2017 11:45 am
Thanks for your thoughts everyone..thinking I'll be going with the front(accessories) battery. Need to find out what measures to take now to eliminate any risks from doing any damage to my solar power setup, I'm guessing it's going to be a fuse inline from the battery to solar controller..can anyone confirm the setup of having solar alongside the split charge setup it's currently fitted with a 15A fuse. Panels are 2 x 110 watt. Once again thank you in advance .
DanTe
Postby grandads_shed » Wed Sep 27, 2017 3:26 am
sorry if this is not allowed admin , i dont know if there are any rules about posting outside links ,
i would sujest joining the self build camper group on facebook , there are over 11000 members and they have full experience in solar and split wiring campers ,
https://www.facebook.com/groups/330513639669/
grandads_shed
Postby the dutch guy » Wed Sep 27, 2017 7:08 am
DanTe wrote:Thanks for your thoughts everyone..thinking I'll be going with the front(accessories) battery. Need to find out what measures to take now to eliminate any risks from doing any damage to my solar power setup, I'm guessing it's going to be a fuse inline from the battery to solar controller..can anyone confirm the setup of having solar alongside the split charge setup it's currently fitted with a 15A fuse. Panels are 2 x 110 watt. Once again thank you in advance .
2x 110W=220W=15A@14V. You will blow the fuse every time you are in full sun. Make sure the solar mppt controller is correctly rated for those panels, do not exeed 80% load on the mppt solar controller. If you do not have a mppt controller you need to get one, regular controllers have utter shit efficiency wich means you will not get the rated power from the panels. Also have 2.5mm wire, the constant load will heat up thin wires making a fire hazard. Use real copper automotive wire, not that copper clad aluminium rubbish.
If you have a split relay you need to make sure it can sense both sides and trigger when any side gets above 13.2V. That meams the solar will charge the starter battery when the aux battery gets full.
Mk6 SWB TDCI 125
the dutch guy
Postby v8dave » Wed Sep 27, 2017 1:29 pm
I'd connect to one of the ford provided power points on the rear of the driver's seat.
One of these is rated 60 amps from memory.
mk7 08reg 2.4 T350 LWB MHR RWD
mk6 X reg 2.4 T350 LWB MHR RWD - scrapped
mk4 J reg 2.5 L300 LWB MHR RWD - sold on
Notice a trend there ? not too big and not too small
v8dave
Postby ake » Wed Sep 27, 2017 6:38 pm
v8dave wrote:I'd connect to one of the ford provided power points on the rear of the driver's seat.
All 3 are 60 amp rated
2011 Ford Mondeo 2.0 Titanium X
4 x Customs
2 x 350 MK7
7 x 260 MK7
Or is it something worse?
Postby Beaker » Wed Sep 27, 2017 7:17 pm
Just to confirm - are you fitting another leisure battery (or more than one) to the existing set up under the seats?
It will make a difference on how you can wire things up.
Also, what does your split charge kit consist of?
Beaker
Users browsing this forum: 955itriple, steviebee
