D2FA to D4FA motor difference on power etc
Postby Mike Saunders » Wed Sep 20, 2017 2:29 am
Hi All need some help thanks
Putting a D2FA Motor into a van that had a D4FA motor
D2FA motor has 90 HP AT 4000 RPM & the D4FA has 120 HP AT 4000 RPM
Do i Need to change injector pump , injectors , turbo over to get the power back
Or do i need to change computer over etc
BIG THANKS Mike
Mike Saunders
Re: D2FA to D4FA motor difference on power etc
Postby ake » Wed Sep 20, 2017 6:30 am
Use 120 pump, injectors, ecu and turbo
Postby Mike Saunders » Wed Sep 20, 2017 9:42 pm
ake wrote:Use 120 pump, injectors, ecu and turbo
thanks for that was thinking would need to
Mike Saunders
Postby toppetsaha » Sun Sep 24, 2017 8:11 pm
You would also need to keep the inlet manifold & egr from the D4FA engine as the other one is smaller.
MK1 - Camper project
MK6 2.4 75ps
MK7 2.4 100ps
toppetsaha
