POO45 Fault code.
POO45 Fault code.
Postby rsjon » Thu Sep 21, 2017 4:48 pm
Mk7 2012 2.2 125PS RWD is slipping into limp mode with MIL and Powertrain light on, generally when on high load up a hill.
Read codes: P0045 Turbo boost control solenoid open circuit.
The turbo on this van is, I believe, a VNT turbo (variable vane).
The vane angle controls the boost and the vane angle is controlled by the electronic actuator on the front of the turbo.
If this is all correct, is the fault telling me there is an electrical open circuit on the electronic actuator?
If so, does the whole turbo assembly require replacement?
Thanks,
Jon.
rsjon
Re: POO45 Fault code.
Postby Punto443 » Thu Sep 21, 2017 7:06 pm
No the electronic actuator can be bought seperatly.
Mk7 61 260 115ps in ink blue, It's not a stripe, it's a swoosh!
my mk7
my old mk6
my xr3i
2011 qashqai.
Punto443
Postby knobby1 » Thu Sep 21, 2017 8:55 pm
What Punto said...although I'm surprised she went into limp mode with that single code :? I may be wrong though....Are/were there any other codes present, historic or pending..??
Postby rsjon » Fri Sep 22, 2017 8:49 am
Thanks for replies.
Definitely only code.
Codes read with a Snap On scanner.
Power train cog light and anti skid symbol were lit as well.
All cleared immediately but come back (along with code) after next high load drive.
Jon.
rsjon
Postby knobby1 » Fri Sep 22, 2017 9:27 am
rsjon wrote:Thanks for replies.
Jon.
If that's the case then there must be other codes...the turbo actuator...and the other two as well..!
Postby rsjon » Fri Sep 22, 2017 7:30 pm
Sounds reasonable.
I will check and report back.
Jon.
rsjon
Postby rsjon » Sat Sep 30, 2017 5:36 pm
No other codes logged.
Removed turbo and replaced actuator.
Reassembled and all is well.
No lights, no codes, no limp home.
Thanks for replies, thought you would like to know the outcome.
Jon.
rsjon
Postby Punto443 » Sat Sep 30, 2017 5:38 pm
Always nice to hear a happy ending :)
my mk7
my old mk6
my xr3i
2011 qashqai.
Punto443
