Transit mk6 2.0 12.1 volts engine running
Postby Codex » Thu Sep 21, 2017 7:12 pm
Bought a transit mk6 as a project, battery light on the dash, 12.1 volts at the battery whilst running, found a small broken wire (red+) at the jump start point under the bonnet, fixed it and rechecked (12.1 volts)
Where is the fusebox and what fuse controls the smart charge system if it is fitted?
Codex
Re: Transit mk6 2.0 12.1 volts engine running
Postby ned » Thu Sep 21, 2017 9:51 pm
viewtopic.php?f=40&t=71739
The burnt wire in the engine bay near the red + jump point is the glow plug fuse link.
With the van running rev it above 3k revs and re check, if the running voltage goes up to 14.4v you have a lazy alternator. N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby Altransit » Thu Sep 21, 2017 11:36 pm
nedforceone wrote: you have a lazy alternator. N
With a visible charging light, and a running voltage of 12.1v, I would say that it's more of a " stuffed" alternator, and needs replacing :wink:
Postby knobby1 » Fri Sep 22, 2017 12:22 am
+1..^^
Possibly the brushes are worn or the regulator on/in the alternator is duff...!
Postby the dutch guy » Fri Sep 22, 2017 3:38 pm
+1..^^
and the bearings are shot.
Mk6 SWB TDCI 125
the dutch guy
Postby Thequeenscheese » Fri Sep 22, 2017 6:03 pm
I'd give all the come toons a once over also and a clean up, check the terminals are tight etc..but as others say prob the alternator on its way out have you checked it's voltage while revving?
2.2 tdci T280
Thequeenscheese
Postby Thequeenscheese » Fri Sep 22, 2017 7:26 pm
Or connections would be a better phrase haha
2.2 tdci T280
Thequeenscheese
Postby v8dave » Fri Sep 22, 2017 8:50 pm
Codex wrote:Where is the fusebox and what fuse controls the smart charge system if it is fitted?
Mk6 fuses info is here viewtopic.php?f=40&t=71739
And Smart Charge on a mk6 - don't think so.
mk7 08reg 2.4 T350 LWB MHR RWD
mk6 X reg 2.4 T350 LWB MHR RWD - scrapped
mk4 J reg 2.5 L300 LWB MHR RWD - sold on
Notice a trend there ? not too big and not too small
v8dave
