knobby1 wrote:I have a 4000lb winch in the back of my Mk7 RWD LWB....It's actually bolted through the floor just behind where the bulkhead would be, it a little off center towards the drivers as the rear of the gearbox and the change cables etc are under there and the fuel tank is towards the passenger side. I used 4"x2"x1/4" support plates underneath too, plenty strong.
I use it to pull my jet powered Go-Kart into the van, it only weighs ~165kg though, the winch does it easily.
bambi mk 1 wrote:Can you not drive it in Knobby
garethdavies95 wrote:So basically remove the heavy Transit plate and fit a witch in the gap? Would the bulkhead be strong enough to support a 500kg pull?
Gareth
MK7 user wrote:bambi mk 1 wrote:Can you not drive it in Knobby
pmsl.
His Lordship...alloy ramps...120 mph, all mentioned in the same sentence.
MK7 user wrote:Top draw Lordy....you've got some good video's there.
loot wrote:Is that you with the muffs on whilst trying to burst everyone else's eardrums?
I name that machine the 'how fast can you die machine'
Quick question tho, what's the steering wheel for? Parking?
knobby1 wrote:loot wrote:Is that you with the muffs on whilst trying to burst everyone else's eardrums?
Aye...that be me..
The steering wheel is for steering mate...parking is an optional extra..
