nmartin546 wrote:Thanks I would have thought he could get the files he says he needs
nmartin546 wrote:I have a transit I want to remap but I've seen on van tuner that he doesn't remap these any more ?
wojciech wrote:nmartin546 wrote:I have a transit I want to remap but I've seen on van tuner that he doesn't remap these any more ?
Mk6 2.0 tdci is impossible to remap through OBD. It is possible only directly on chip removed from PCM. It is very deep and danger intervention in van electronic.
I didn't want to do it and I have installed in my Mk6 2,0 tdci good digital box (V-Tech), practically effects are close to remaping. I use it now 8th year. It is complicated and expensive unit, it isn't box with one resistor inside...
It has 10 positions switch, switching over is very easy, two minutes. In newest V-Tech boxes it is possible throgh smartphone.
On position 0 (without box) my 2,0 tdci has 132HP/292Nm, on position 4 it has 145HP/346Nm, on position 6 156HP/371Nm but this one with engine knocking. So - I don't use higher positions. Usually I drive on 2nd position, it is - I think - about 140HP. And I like it.
People who talk only negative things about Delphi system haven't any long experience about it. Well done injectors and pump with genuine parts works without problems up to 200.000 km = 125.000 miles. Of course it isn't the best injection system in the world, but quite good. I know worse systems...
http://powerchip.vtechtuning.eu/index.p ... ommon/home
MK7 user wrote:
Most people who have one (or had one) don't have the same knowledge & experience you have....so they are at the mercy of a garage who's primary goal is to make money as regular as they can.
wojciech wrote:
Problems with Delphi injection system in Mk6 tdci it is piece of cake - compared to whole rest of problems in this van.
the dutch guy wrote:but such a repair is still cheaper then getting another van with someone elses problems. nobody sells a car that has no problems, otherwise they would not sell it.
MK7 user wrote:
On a 12~14 year old van, the cost of repairs is more than the van is worth
don't take the exeption as a rule.MK7 user wrote:Not so....I bought a Mk7 without a single problemthe dutch guy wrote:but such a repair is still cheaper then getting another van with someone elses problems. nobody sells a car that has no problems, otherwise they would not sell it.
