Beaker wrote:olympia5776 wrote:Water off your boots......
Thats either coming in through a leaking windscreen or down the A piller via the stupid trim clips that hold the external plastic trim on.Either way it will find it's way right down to the inner step as well as sitting under the floor mat.
You have to lift the plastic floor mat and undo the two 10mm nuts under the step that retain the plastic step covering and have a good look at the condition of the metal. You will also have to get down and dirty and check underneath . If it's been left unwashed underneath and laden with salty mud then it won't outlive your trusty hi ace......
The chassis construction on these MK 6/7's is abysmal and with the drain routes designed to exit through the front of the sills the inner box sections are quietly rusting away unless you flood them with a runny waxoyl mixture.
Check it over forensically.
That's an interesting idea - I never even thought of that. I've definately not got a leaking windscreen so I might remove the A pillar trims and have a look.
Any idea how to remove them?
They simply prise off . The clips ,or most of them , will break so best get some replacements before you remove them. Like you i was certain the windscreen seal was ok but then I had to have it replaced and the fitter showed me two 1.5 inch sections that were passing water. I ran a solid bead of pu sealer along the top of my screen after discarding the plastic trim fitted and again sealed off those trim clips after finding water ingress under the drivers A piller. Ihad ignored the damp under the floor mat for a couple of years and ended up having to cut out two areas and weld in fresh metal.
Since all above was done there has been no reoccurance of water getting in.
I cannot emphasise how important it is to get under the, or any,transit to check the floor and chassis. Mine has had the box and sill cavities flooded with waxoyl every year inthe 13 years I've owned it but I still had to replace a box section last year due to the open design of the chassis sections where they meet or have factory holes drilled into them.
Over here in Ireland many mk 7's are being scrapped due to chassis rot.
Good luck with your search.
