Bad start and cutting out
Re: Bad start and cutting out
Postby MJ80 » Wed Feb 21, 2018 9:05 pm
I'm going to see if I can do a bundle deal somewhere, possibly including the rail. The testing place want a €115 for the injectors to be overhauled. I'd rather get everything from one place especially as one of the injectors looked like it may be from a Mondeo, it had a different locking sleeve which had a flange on it. For the sake of a couple of quid I think it would be the better option.
I'll look how much the pipework is, otherwise I'll try and clean it the best I can.
2003 Mk 6 125 tdci T350 - I have no other choice
MJ80
Postby ned » Wed Feb 21, 2018 9:14 pm
Give PF Jones a call they are very helpful, I think if you buy remanufactured pump and injectors of them they give you cash back for your old parts which helps. They are members on here so you might be able to worm a discount out of them :wink:
I don't think the fuel line are to expensive, its cleaning the rail and tank that's the hard part. N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
