loot wrote:It'll take plenty more oil without the filter
ian mk6 wrote:I`m sure the larger, upgraded sumps will catch someone out though, if they haven`t already.
mjsroofing wrote:Min to max I thought was a litre on all vehicles.
I might be corrected.
Dip stick will give you a accurate enough measurement.
Altransit wrote:mjsroofing wrote:Min to max I thought was a litre on all vehicles.
I thought the same thing, which is why I always put half a litre in from the low mark.
I don't like to overfill, and it doesn't need to be full.
ian mk6 wrote:Hallii wrote:On my 2.2 I found it impossible to get a accurate oil level reading until I found the solution.
The dip stick is such a good seal to the tube when it is pulled up a vacuum pulls oil up and gives a false reading.
So now I pull the stick out, wipe it and only put it in until the O rings rests on the top of the tube.
That means you have to add about 15mm to the level since that is the amount of dip stick not pushed in.
It works for me!
Geoff
This is unecessary because even if it did create a vacuum, the oil level in the tube would only rise by the same distance you have moved the dipstick and not alter the measurement.
loot wrote:My next door neighbour bless her, she was low on oil (1.2 corsa b) so she put a gallon in Yeah that's why it isn't running very well mrs
Users browsing this forum: DJPA
