knobby1 wrote:I doubt you'll need a new head...possibly the rocker ladder may be cracked/broken or the ladder bolts may have pulled... but the head itself should still be ok.
Valves rarely bend as they're straight on to the pistons, they're more likely to lift the rocker ladder or pull the bolts, very common and repairable.
A new or second-hand ladder assy and a nice new timing chain/tensioner kit should see you sorted.
karl wrote:He says 06 125 so will be a tddi so the cam carrier will be broken mainly on the inlet side so new head will be required as you carnt miss match the cam carrier
wojciech wrote: The rocker and cylinder head are always one inseparable part, with one collective number, from the begining together tooled during production. It is wrong idea put on head the rocker from another head.
https://www.catcar.info/ford/?lang=en&l ... I3Mg%3D%3D
knobby1 wrote:
Hopefully it's just pulled a couple of bolts and he can repair the threads.
Usually if couple of bolts are pulled out - rocker is broken... It is very fragile part.
Ok, you are optimist , I am pesimist ...
knobby1 wrote:wojciech wrote:Ok, you are optimist , I am pesimist ...
LOL...
Altransit wrote:In a land full of poisonous snakes and spiders, it doesn't pay to be a pessimist Have you seen Crocodile Dundee
onemanpeloton wrote:Thanks again. Hoping to keep this repair as cheap as poss as the garage quoted me £1700. £700 of which is a brand new head from Ford
knobby1 wrote:onemanpeloton wrote:Thanks again. Hoping to keep this repair as cheap as poss as the garage quoted me £1700. £700 of which is a brand new head from Ford
1700...quid.. I think You can get a whole new lump..including fitting for that..!
