Under body sealing
Under body sealing
Postby x818 » Tue Oct 10, 2017 9:12 pm
I need to seal underneath of van as a preventative measure, never bothered with previous vans, both died of rust related causes!! I’m fairly handy so was planning on doing this myself. There is no welding needed at the moment, and brake pipes were done at last MOTFew bits of advice needed first:
1. What prep work do I need to do beforehand.
2. What underbody seal is best?
3. Is it worth getting someone to do it for me as I’m lazy
Any help or advice appreciated
Thankd
x818
Re: Under body sealing
Postby ned » Tue Oct 10, 2017 10:12 pm
There's a company up Warrington/st Helens way that does it but I cant remember what there called :roll: N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby x818 » Tue Oct 10, 2017 10:13 pm
nedforceone wrote:There's a company up Warrington/st Helens way that does it but I cant remember what there called :roll: N
Not too far from me then, may give them a tinkle but quite fancy giving it a go myself
x818
Postby ned » Tue Oct 10, 2017 10:21 pm
I was working not far from you this week up smellesmere port :wink:
Anyway I have to do mine soon so what I was going to do was, sand down any surface rust with a flap disc on my angle grinder then use underseal all over the under carriage and spray waxoyl into all the holes in the chassis sections, I was/am also thinking of stone chip the inner wings and rear wheel wells :D N
ned
Postby x818 » Tue Oct 10, 2017 10:23 pm
I’ve been in frodsham last week hate the m56 I was just going to smash everywhere with underesal, including inner wings, wont look dirty then
x818
Postby ned » Tue Oct 10, 2017 10:29 pm
I don't bother with the m56 I tend to go redneck, past stanlow the up through frodsham, Avonlea and delemere forest back to stinky Winsford :lol:
I believe if you stick the tin of underseal into a bucket of warm water it makes application a lot easier. I have been looking at the rustoleum products recently. N
ned
Postby x818 » Tue Oct 10, 2017 10:30 pm
nedforceone wrote:I don't bother with the m56 I tend to go redneck, past stanlow the up through frodsham, Avonlea and delemere forest back to stinky Winsford :lol:
Was also considering spray application I’m in process of acquiring a compressor, too many ideas and too little action I thjnk
x818
Postby 1958 harry » Tue Oct 10, 2017 11:30 pm
There's Krown rust proofing.
Gonna get them to do my mk7 Transit Sport Van once I get it.
VW Transporter Combi van
VW Beetle 2.0 tintop
Audi Q3 Quattro SLine Plus
Grown up in/around Transits, my dad has a 2010 115 T350 Transit
1958 harry
Postby Beaker » Tue Oct 10, 2017 11:34 pm
I need to get mine done ASAP as well. I was looking at using Dinitrol as I can get that from Rejel in Bedford. Dinitrol is supposed to set harder than waxoyl and does not need reappyling as often.
Dinitrol are based in Warrington, so it might be worth you guys getting it direct from them if you want to use it.
Someone I know told me to use Upol Raptor in the wheel arches - the pickup truck bed liner stuff.
2011 SWB medium roof 2.2l Mk7 115 T300 in Frozen White. Stealth Camper converted.
"It's better to burn out, 'cause rust never sleeps..."
Beaker
Postby ned » Wed Oct 11, 2017 2:14 am
That's the stuff punto used that dinitrol, I couldn't remember the name of that either before :roll: Upol raptor is that like that line x stuff they use in America on truck beds ?. N
ned
Postby the dutch guy » Wed Oct 11, 2017 4:40 am
Use the 2 part chemicals for underbody protection. After that is set and dried out you can use dinitrol for the cavities (only!). The crap gets EVERYWERE. I have a alfa 156 fully restored and protected by it top to bottom and it works but man is it a bitch to clean off were you need to remove it.
Mk6 SWB TDCI 125
the dutch guy
Postby Beaker » Wed Oct 11, 2017 8:58 am
nedforceone wrote:That's the stuff punto used that dinitrol, I couldn't remember the name of that either before :roll: Upol raptor is that like that line x stuff they use in America on truck beds ?. N
Yes, Upol Raptor is a truck bed liner. The guy who suggested it says it's amazing on wheel arches as it won't wash out and prevents stone chip damage. He said to just get a can and paint it on. And you can get it in different colours too. Upol is a common brand of pro auto paints so you should be able to get it fairly easily - I've seen Raptor for sale on ebay.
You can get kits direct from Dinitrol in Warrington with everything you need for different sized vehicles, in either Schutz gun or aerosol spray can versions. If you are local enough to collect it saves a hefty amount on postage.
the dutch guy wrote:Use the 2 part chemicals for underbody protection. After that is set and dried out you can use dinitrol for the cavities (only!). The crap gets EVERYWERE. I have a alfa 156 fully restored and protected by it top to bottom and it works but man is it a bitch to clean off were you need to remove it.
By two part chemical, do you mean the rust converter stuff you use before the wax coating?
Beaker
Postby x818 » Wed Oct 11, 2017 10:02 am
Warrington is close enough to me, I’ll price both options up as I’m only planning on keeping the van for 3-4 years so don’t mind reapplying underseal
x818
Postby dethleffs » Wed Oct 11, 2017 6:46 pm
I have used Dinatrol cavity wax inside the chassis, crossmembers and sills.
Mine was rusting under the factory stonechip so spent hours scraping it off first.
Used a Shultz gun with a long lance and blathered it. A very messy smelly job, but I am pleased with the results.
One life, live it
dethleffs
Postby x818 » Wed Oct 11, 2017 8:24 pm
dethleffs wrote:I have used Dinatrol cavity wax inside the chassis, crossmembers and sills.
I’m thinking along the lines of a sanding disc on a 4 1/2 in grinder to remove the loose, then unsure wether to jet wash or just a good scrub and rinse underneath(don’t want to damage anything). Question is how do I get under properly with no ramps
x818
