nedforceone wrote:I do believe my good man you need the mk2 non digital mondeo clocks and slightly modify the pcb N
viewtopic.php?f=18&t=74155#p628381
Altransit wrote:nedforceone wrote:I do believe my good man you need the mk2 non digital mondeo clocks and slightly modify the pcb N
Didn't we work out that the Mk5 TD clocks will fit and work, Ned
nedforceone wrote:Erm...I didn't know that so are the mk5 TD clocks plug n play The local junkyard to me have a few mk5's in so I might have a looksy if any are TD, I quite fancy a rev counter on my van N
Altransit wrote:nedforceone wrote:Erm...I didn't know that so are the mk5 TD clocks plug n play The local junkyard to me have a few mk5's in so I might have a looksy if any are TD, I quite fancy a rev counter on my van N
Oh OK, I thought we had had this discussion before, and you confirmed that the cluster was the same ................. maybe i dreamt it
It would have to be the later ones, '97 on I think, as the early ones had a cable driven speedo which the early Mk6 never had
I'm sure Matt will be along soon to put me straight
nedforceone wrote:Mr Altransit might be the best man to ask about the images
I'm sure but not 100% that the pcm will supply the rpm for the counter. N
karl wrote:i have modified clocks in mine and these were bought from a member here
mondeo mrk 2 a think
but they work great fuel gauge works as it should all i done with them was put my millage counter in them
nedforceone wrote:karl wrote:i have modified clocks in mine and these were bought from a member here
If you ever get a chance to pop them out and post a picture of the modification that would be muchly appreciated N
