Smokin'
Smokin'
Postby Oldvandriver » Fri Oct 13, 2017 5:28 pm
Well, for the second time I've borrowed the old mk6 I may buy,and noticed this time that She's smoking like a b*stard !! and running a bit rough. So I've dumped some Wynns injector cleaner into the tank and run it for about an hour but that's all today. The smoke is grey/white and if I rev the engine to 3 thou plus when static the world disappears ! Oh I pulled a pretty foul air filter out of its hole too. What can I do to improve the situation do you think ?
She starts dead easy, there doesn't seem to be much smoke and derision when I pull off the oil filler cap, has a reputation for not using much oil or water, has been to Ireland three times this year (so obviously is reliable).but I can't go about laying a smokescreen ! I haven't had so much room on the road for years !!
Is there anything I can do about this ?
She is a SWB low roof,2.0L 85 T280 built 2005.
Oldvandriver
Re: Smokin'
Postby ned » Fri Oct 13, 2017 6:31 pm
Sounds like a fueling issue, a good service and check the timing. N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Re: Smokin'
Postby v8dave » Sat Oct 14, 2017 10:12 am
There is an online manual.
Here is the diagnosis page for 2.0l.
I had to zoom in quite a bit to read the text :!:
mk7 08reg 2.4 T350 LWB MHR RWD
mk6 X reg 2.4 T350 LWB MHR RWD - scrapped
mk4 J reg 2.5 L300 LWB MHR RWD - sold on
Notice a trend there ? not too big and not too small
v8dave
Re: Smokin'
Postby the dutch guy » Sat Oct 14, 2017 10:38 am
do a full service (oil, filter and get a ORIGINAL TDCI fuel filter from ford!) and chuck in 0.5 litres of kerosine (ask a farmer or something) on a full tank and drive it empty in as few runs as possible with lots of highway use. report back.
Mk6 SWB TDCI 125
the dutch guy
Re: Smokin'
Postby Altransit » Sat Oct 14, 2017 2:45 pm
the dutch guy wrote: get a ORIGINAL TDCI fuel filter from ford!
I agree about the service, but you don't need a TDCi filter for a TDDi (85ps)
Re: Smokin'
Postby v8dave » Sat Oct 14, 2017 2:53 pm
the dutch guy wrote:chuck in 0.5 litres of kerosine
Is that some branded product or do you mean Kerosene.
What is it supposed to achieve. Diesel and kerosene are very similar hydrocarbons.
Diesel fuel normally has molecules with between 10 and 15 carbon molecules in it, while kerosene has between 6 and 16.
Diesel has a regulated maximum sulfur content but most kerosene these days is probably low sulfur as well.
v8dave
Re: Smokin'
Postby Retired John » Sat Oct 14, 2017 11:04 pm
Not sure what the kero will achieve we often use kero in winter at up to 205 for easier starts with machinery , works with transits as well , most kero sold here for farm use is I have been told out of code jet A :shock:
Retired John
Location: Casino NSW Australia ......... 2002 125 T425 TDDI
Re: Smokin'
Postby the dutch guy » Sun Oct 15, 2017 2:46 am
Altransit wrote:I agree about the service, but you don't need a TDCi filter for a TDDi (85ps)
missed that it was a DI.
v8dave wrote:Is that some branded product or do you mean Kerosene.
just regular kerosene, the fuel, nothing special. injector cleaners are basically 97% kero with some glitter added to jack up the price 5000%. chucking in half a liter actually does something. diesel is really oily, kero basically works the same as terpentine.
Mk6 SWB TDCI 125
the dutch guy
Re: Smokin'
Postby bambi mk 1 » Sun Oct 15, 2017 2:53 am
That's the problem with owning a mk 6 tdci,its furkes your head up :mrgreen:
bambi mk 1
Re: Smokin'
Postby Oldvandriver » Thu Nov 16, 2017 6:31 pm
To anyone who might be interested, This seems to have been caused by the timing chain slipping, causing the cam carrier to crack and make everything work .... Badly !! had it sorted with a second hand head & carrier, seems ok now (well as fine as a twelve year old motor usually is !)
Oldvandriver
