Only knocks at 2 to 2 half thiusand maily on miteraway been told inject 3 4 wont talk to computer . But also been told injecters atlre new . Were do i go from hera
Sent from my SM-A500FU using Tapatalk
Altransit wrote:First thing to check when you hear knocking on these engines, is that the injector clamp bolts are tight, and that the clamp is intact. If they re-used the old bolts when fitting the injectors, they've almost certainly come loose
