Battery isolator stops van starting
Re: Battery isolator stops van starting
Postby mjsroofing » Fri Oct 20, 2017 8:26 pm
I remember when I had my mk6 transit, if the battery went under a certain voltage it wouldn't even try to start, slight touch of a jump lead and she'd fire up.
It was as though it had a cut off switch, under certain fraction of a volt and the ecu don't activate the starter or something.
If this is the case maybe the isolater is drawing the voltage down a little bit.
www.mjsroofing.co.uk
2009 2.2 tdci 115ps just over 51k and sweet as a nut ( so far )
2002 2.0 tddi 100ps. Over 205k still sweet . Now owned by Jay.
2001 escort van 75, 1.8 turbo intercooler. scrapyard heaven
1995 escort van 50, 1.8 straight diesel, scrapyard heaven.
mjsroofing
Postby Bewick » Wed Mar 21, 2018 8:17 pm
So, replaced the isolator switch with thishttps://rover.ebay.com/rover/0/0/0?mpre ... 1977293253
Same problem. With the switch in place (in the negative) and it deisolated there's current to operate the radio etc. When I turn the key all the usual lights come on but it won't start, same sounds as when the battery's flat
BUT
When I connect the negative straight to the battery without the switch in place she starts fine. Why does having the switch stop the van starting?
I'm struggling with this one now.
Bewick
Postby the dutch guy » Thu Mar 22, 2018 4:29 pm
Please draw the schematic how it is connected now
Mk6 SWB TDCI 125
the dutch guy
Postby Bewick » Thu Mar 22, 2018 5:31 pm
I can't draw it I'm afraid but I can try to describe.
I took the negative cable off the battery and put it on one pole of the switch. I then ran a fresh cable from the switch to the negative battery terminal. It works to disconnect. It works to reconnect and run the central locking and everything, just not to start the engine.
I hope that's clear. It's very simple wiring so I hope I've done something obvious wrong rather than needing to buy yet another switch.
Bewick
Postby knobby1 » Thu Mar 22, 2018 7:25 pm
Bewick wrote:I can't draw it I'm afraid but I can try to describe.
I wonder if the switch can "actually" handle the quick high current hit when the starter is first activated..?? Some cheap ones say they can but throw in the towel when it comes to delivering the current.
Postby dumper » Thu Mar 22, 2018 8:15 pm
When I fitted a master switch to my mk6 instead of using cable from battery to master switch I used a flat pice of bar drilled a hole in each end and bolted master on one end and battery on the outher end but I had the room to do so as it only had one battery the switch I used was a heller heavy duty one that we used on Crains and diggers at work
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
