ECU swap and re program procedure
Postby grembo » Tue Oct 17, 2017 11:54 am
has any one done a thread on a walk through explanation of the best practice to swap and reprogram a ECU for the 2.2 TDCI (puma engine) 11 reg
there seams to be so many conflicting bits of info about on the net
so i thought best to ask the guys that know on here
i have the old eco removed as its dead and smell of burning electronics
i have a second hand eco here from a same model van
and access to a computer with the ford IDS installed
i have the van on charge
and i have access to the in-code out-code when required to set PATS up
so any links to threads that cover the replacement and re programming will be greatly appreciated
grembo
Re: ECU swap and re program procedure
Postby v8dave » Tue Oct 17, 2017 8:03 pm
Don't know about later versions but if you have V86 of ids then you need extended programming enabled.
After that just follow the instructions for module replacement.
Have read through the "idiots guide to ids" viewtopic.php?f=5&t=155150&start=1245&hilit=ecu+program
mk7 08reg 2.4 T350 LWB MHR RWD
mk6 X reg 2.4 T350 LWB MHR RWD - scrapped
mk4 J reg 2.5 L300 LWB MHR RWD - sold on
Notice a trend there ? not too big and not too small
v8dave
Postby grembo » Tue Oct 17, 2017 8:32 pm
also looking for file 9C11-12K532-HJ.vbf
grembo
Postby knobby1 » Tue Oct 17, 2017 9:20 pm
grembo wrote:also looking for file 9C11-12K532-HJ.vbf
I have this file at home in .zip format..! Am at work at the moment...
Or...you could possibly download it from here:
https://www.fordtechservice.dealerconne ... roduct=IDS
Postby grogan197 » Tue Oct 17, 2017 9:22 pm
Follow this link https://www.fordtechservice.dealerconnection.com/vdirs/wds/PCMReprogram/DSFM_PCMReprogram.asp?swproduct=IDS and enter your filename and it will download the calibration file for you
2006 MK6 2.0 125 TDCI - Luton Camper Conversion
2007 MK7 2.2 110 TDCI SWB
Ford Diagnostics
Where to buy an ELM327 and how to use with ForScan
grogan197
Postby grembo » Wed Oct 18, 2017 6:07 pm
if replacement ECU is from a van with same engine etc
will it run by just enabling the PATS system again ?
will it actually run then with the mis matched injector codes etc to get the vehicle moved ?
or will it have to have a complete reprogram calibration files etc done injector codes and pump learn
thanks
mark
grembo
Postby Punto443 » Wed Oct 18, 2017 6:12 pm
If replacement Ecu(pcm) is from the same spec vehicle, then it will run with only pats coded.
The injector correction codes and pump/injector learns are for calibration and fine tuning.
But I wouldn’t run it long without doing them.
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby knobby1 » Wed Oct 18, 2017 7:49 pm
Punto443 wrote:If replacement Ecu(pcm) is from the same spec vehicle, then it will run with only pats coded.
+1..^^
Postby grembo » Thu Oct 19, 2017 3:16 pm
hi guys just about to install the replacement eco
which is best option to be using from IDS menu
Programmable Module installation
or
Module reprogramming
is there a way of backing up my old calibration file from old eco ?
as its wanting to use a later calibration file which i have downloaded already
i have retreaved the Injector codes ready to be changed already
thanks on advance
grembo
grembo
Postby grembo » Thu Oct 19, 2017 4:21 pm
IDS 105.01 VM machine works fine with clone VCM may have to use your drivers if its an older version of clone
https://drive.google.com/drive/folders/ ... GRYX01qWlU
grembo
Postby grembo » Sat Oct 21, 2017 3:36 pm
quick question
is it posable to choose which calibration file you want to put into PCM ?
apart from renaming the one you want to the name that its asking for when doing update
cheers
grembo
grembo
Postby v8dave » Sat Oct 21, 2017 3:41 pm
grembo wrote:quick question
cheers
grembo
Don't think that will work as the calibration name is in the code contained in the file.
v8dave
Postby grembo » Sat Oct 21, 2017 4:13 pm
yes noticed that but thought it may just dump the file in
will have a go and see when i get the spare PCM next week
cheers
grembo
grembo
Postby grembo » Sat Oct 21, 2017 4:15 pm
has any one access to as built files
would like to check what was on mine compared to whats on now
grembo
Postby v8dave » Sat Oct 21, 2017 4:41 pm
You can find the original factory calibration on a sticker on the passenger door pillar.
If you have kept ids log files the calibrations installed can be read from those.
v8dave
