Electrical issue
Electrical issue
Postby Eurotransit » Tue Oct 17, 2017 12:45 pm
Hi,
I'm faced with the following problem and hope you guys can help diagnose.
The transit starts and runs fine, but it's dead completely as soon as the key is removed. The interior lights are immediately dead, the radio presets reset, etc. It's like there is no continuous power. Yet insert key and ignition on etc and all comes to life and the car starts as well.
Car has one battery fitted currently, was usually a two battery setup, but the second (non starter) battery boiled and died. At first on one battery there were no issues, but a little while later the problems as described started appearing.
Is this a main (under bonnet) fuse? Is this a sticking or broken relay? Anyone got a clue?
Thanks in advance for any pointers.
Eurotransit
Re: Electrical issue
Postby blue estate » Tue Oct 17, 2017 12:51 pm
REPLACE THE SECOND BATTERY !
Your van is set up for a 2 battery system , I'm supprised you've not had running and dash issues either
2nd battery does lights radio ecu locking when engine is switch off
Other battery is for starting only
72plt MG 5 ev estate Battery car
blue estate
Postby Punto443 » Tue Oct 17, 2017 1:18 pm
+1
Batteries are not simply tandem, they both serve a different function on the van, one is the dedicated starter battery and one is the Aux system battery.
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby loot » Tue Oct 17, 2017 1:31 pm
If you want a single battery system you need to bypass the battery saver relay.
Personally I'd fit 2 strong batteries as intended.
Bit silly really, like saying yes I'm a runner but chopped a leg off and now i seem to go round in circles :lol: :mrgreen:
Ids map here
loot
Postby Eurotransit » Tue Oct 17, 2017 1:37 pm
Sounds credible and almost humiliatingly simple. My mind must be skewed as to when the problem started... I thought it had worked correctly on one battery for a short while and as such had not made the connection.
The car will receive a new battery soon. Reason for not immediately replacing battery was twofold. Dealer upon sale of vehicle had described the second battery function as aux in the sense of me using it to on occassion power a coolbox/mini fridge and fan for the dogs. A power outlet was provided for these. Not as you stated for starting and vehicle aux functions. And the other is financial. A decent battery was an expenditure I could do without at the moment. So thinking I'd be ok on one battery for a while, I had postponed that a little.
Eurotransit
Postby Airthies » Tue Oct 17, 2017 3:30 pm
My front batt died and I disconnected the front negative and bridged between the two positives. Worked fine for a couple of months but I also have a couple of donkey bats in the back for other things which are connected soon as ignition on.
As long as yr main bar is ok I'd reckon it's be ok for a while but there's a reason there's two under there
Especially coming into colder weather it's going to get harder.
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Eurotransit » Wed Oct 18, 2017 4:20 pm
A new battery has indeed cured the issues. Thanks!
Eurotransit
