loot wrote:With ids you should see codes.
Has it got 2 batteries under the seat? Do you ever see any strange goings on?
Things that cut out that I'd check are batteries, ignition switch, fuel filter, crank sensor.
An injector leak off test might be an idea, you can also blank the egr with a solid blank, it'll throw the elm but won't pass gas so won't cut out, this is for diagnostic purposes.
However, you should clear codes, drive it a while, then recheck codes and post them up here
loot wrote:Opinions differ on this but if you grab it and it isn't wobbly then that's check 1, check 2 is remove it and check to see if there's filings on the end which could cause it to give wrong signals back to the pcm and confuse it, the crank sensor is cheap to replace.
If you choose to reuse the old 1 then you risk problems as the air gap will be incorrect.
It is located herein the bell housing on top side of the engine it has a wiring connector to it
karl wrote:loot wrote:With ids you should see codes.
"girl filter"
thats a new one to me
bambi mk 1 wrote:loot wrote:Opinions differ on this but if you grab it and it isn't wobbly then that's check 1, check 2 is remove it and check to see if there's filings on the end which could cause it to give wrong signals back to the pcm and confuse it, the crank sensor is cheap to replace.
The one I had was loose in the slot Loot,tightened it up and hey presto Air gaps are for airheads
bambi mk 1 wrote:The vice squad are on the way Don't have ids but never shows on Delphi or Snap on
Users browsing this forum: Crispin007, Google [Bot], Google Adsense [Bot]
