by rckape » Sat Nov 04, 2017 3:46 pm
Hi,
I have a 2007 Mk7, 2.2 TDCi MWB with around 130k on the clock. I've put the last 10k on myself over 12 months.
I have noticed over the last couple of days a rattling kind of noise which got louder on acceleration. I obviously checked on here and the most popular answer was a loose injector or two. I've just taken the air filter box off to have a look, I started the engine and it ticked over OK and I couldn't hear the tapping. I revved it up to replicate the sound and it came back straight away (sounding like it came from the nearside) but before I could check anything out the engine cut out and although the engine turns over a little when I turn the key it will not fire and cut out. I only tried this once more (total of twice after the initial cut out) for fear of doing further damage. There has been no smoke from the back at all (other than the usual puff on starting up in the morning) over the last week or today.
The battery and starter are fine. I had the oil changed at a garage in July, but it is now thick and black - much worse than I'd expect after a few months average use and at the bottom end of the OK marks on the dipstick.
In May I had the EGR seize up on me requiring recovery. I changed this myself and it has been operating ok since - The EM light is still on on the dash and no matter how many times I clear it it always comes back after a five minute drive or idle. I have read somewhere that it probably needs to go back to Ford to have the software updated.
I believe the clutch and possibly the DMF is getting ready for changing, I can feel a vibration in the clutch pedal even without putting any pressure on it. Could it be the clutch or DMF disintegrating and choking up causing the stall?
