by travis_transit » Mon Nov 06, 2017 4:03 am
Hi there,
My 2002 2.4L diesel FT made a strange "tut tut tut tut" metal sound very randomly going down a hill. I pulled over, opened bonnet while running, and it was definitely louder underneath than above engine. I wanted to nurse it back the last few blocks home, and put in reverse and noise went away immediately. Then drove home and sound didn't return. This sounded severe though when it did happen, so I can't just ignore obviously. I've been told it may be my valve push rods, and was asked if they are hydraulic, which I don't know. So firstly - are the push rods for my van hydraulic? If so, then possibly an overdue oil change and new filter should do the trick (here is to hoping!).
Secondly, is it ok to drive my van for the next 2 days if the noise has gone away (I know a stupid question, since you can't diagnose without more info, but a general question really), or am I causing more damage? I can really only do an oil change in 2 days.
Thanks in advance!
Travis
