Hi all,
I've got LEDs in the back of my MK7 to replace the factory fitted candles in jam jars. I've had them in for a year now and they have been flickering, sometimes working/sometimes not (individual lights - there are about 30 LEDs) so I'm trying to sort out why. I think its because the lights dim as they shut off and the dimming action is playing havock with the LEDs (maybe?). I also have a normal 12v (non LED) wired to the same circuit because without it the LEDs stay on very, very dimly when the van is locked. I assume it needs a resistor to shut down the micro amps of current in the system.
Today I have fitted 60 new LEDs and ran the whole circuit through a relay so that a battery live powers the LEDs and the van wiring powers the relay, but they still shut down in a dimming fashion and flicker as the voltage drops on power up/shutdown.
Any ideas how to make them come on and off without the slow rise and fall of voltage? I don't want to put it on a manual switch because I'm lazy and want it to work on the key!
