Mk7 Noisy engine & slow throttle
Re: Mk7 Noisy engine & slow throttle
Postby HuMpH » Wed Nov 15, 2017 6:13 pm
Ok well just picked van up from garage, still the same lol.
They had it on snapon system and got the same 3 faults again, however their advice according to their data is a fault with the ECU.
They said to take it somewhere that specialise in ECU, one good note is they said the Injectors are all working fine and they did the learn routines ect.
I have just been looking for specialist local and nearest would be Andy ( MAYCONTAINNUTS) at askautotech but his site has gone and number no longer works so looks like he no longer trades..typical of my luck atm. :(
Oh well best fire up google
125 T350 Lwb Hitop Rwd now sold.
Mk7 110 T300 Fwd
T-shirts preview Here
HuMpH
Postby HuMpH » Wed Nov 15, 2017 6:15 pm
loot wrote:Hi Get the injectors checked, if it was me I'd fix the glow plugs circuit, most likely need all replacing, if 1 is shorting it can be bringing the battery voltage down which won't help.
Injector fault could be a faulty injector solenoid, pcm, glow circuit, battery, wiring.
Get the mechanic to check the resistance on the injectors, 70 ohms thereabouts according to denso.
Let us know how you get on, Karl is closer to you but I May be able to help if needed.
Cheers loot, you any good with ECU ? :lol:
Someone mentioned Karl but stated he was very busy
Mk7 110 T300 Fwd
HuMpH
Postby loot » Wed Nov 15, 2017 6:48 pm
Have you spoken to Karl? Ask him to replace the glow plugs and ping the injectors etc maybe do the updates. :-)
Ids map here
loot
Postby martynx » Wed Nov 15, 2017 7:47 pm
I am in London but can clone ECU's postally , ( so you plug it in and go without any further programming ) so may be useful if you are short on options on getting a replacement .. its very rare though for it to actually be an engine ECU at fault.
I've a sneaky feeling the injector fault code you had is erroneously reported on some early engine ECU software versions along with the water in fuel one, I have seen it many times before for sure.
for egr/dpf deletes, power tuning, updates,cloning,speed limiter removal,cruise control, euro 3/4/5/6 limiters & key's !
martynx
Postby ned » Wed Nov 15, 2017 8:14 pm
knobby1 wrote:
ned wrote:Karl is also down the road from you in Manchester but he's busy busy busy :wink: N
I'm just down the road a bit too..!! :wink: :roll:
:lol: :lol: :lol: Just a tad down the road. N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby martynx » Wed Nov 15, 2017 8:30 pm
Eh????
Australia isnt it ?? !!!!!! ;)
martynx
Postby knobby1 » Wed Nov 15, 2017 8:37 pm
martynx wrote:Eh????
Aye, it is....that's just doon the road a bit though...init..?? :roll: :wink: :mrgreen:
I've still gotta get my lazy ar$e to GB one day...would be great to finally meet some of you lot..! :D
Postby martynx » Wed Nov 15, 2017 8:40 pm
Haha thought so , come to transitmania one day , especially as its now at Santa Pod :-)
martynx
Postby knobby1 » Wed Nov 15, 2017 8:47 pm
martynx wrote:Haha thought so , come to transitmania one day , especially as its now at Santa Pod :-)
Santa Pod would be good...I could bring the Jet Powered Go-Kart...and charge a fiver each for a run down the track..! :wink: :roll:
Postby bambi mk 1 » Wed Nov 15, 2017 9:02 pm
Might not be a good idea Knobby :wink: viewtopic.php?f=28&t=183234
bambi mk 1
Postby knobby1 » Wed Nov 15, 2017 9:12 pm
bambi mk 1 wrote:Might not be a good idea Knobby :wink: viewtopic.php?f=28&t=183234
Don't worry mate...the silly thing only carries 23Liters of fuel... enough for ~45secs at full noise/full afterburn....can't go too far..!
Postby martynx » Wed Nov 15, 2017 11:41 pm
I'm in!
martynx
Postby knobby1 » Wed Nov 15, 2017 11:52 pm
martynx wrote:I'm in!
LOL..! Not if you look like your Avatar.. :lol: :lol: :roll: :wink:
You'll nae fit in..! :mrgreen:
Postby martynx » Wed Nov 15, 2017 11:54 pm
LOL..! Not if you look like your Avatar.. :roll: :wink:
Thats my wife you plonker !!!! ;)
martynx
Postby knobby1 » Wed Nov 15, 2017 11:55 pm
Oh dear, I am a right plonker...I should've kept my gob shut then..! :wink: :lol:
