Noisey Quack Valve
Noisey Quack Valve
Postby F111ORY » Sat Nov 11, 2017 11:47 pm
I have a swb 2008 Transit and the local garage replaced the egr valve about 18 months ago ( 18,000 miles). The last month the cycle it does every time I stop the engine is getting very noisey. Should I be lubricating it?
F111ORY
Re: Noisey Quack Valve
Postby F111ORY » Wed Nov 15, 2017 8:46 pm
Just bumping this back to the top as I seem to be suffering from invisible man syndrome!
F111ORY
Postby knobby1 » Wed Nov 15, 2017 8:50 pm
F111ORY wrote:Just bumping this back to the top as I seem to be suffering from invisible man syndrome!
You can "re-grease" the little gears inside the stepper motor....but the valve may be clogging up with exhaust spooge causing it to struggle a bit, hence the noisier than normal operation.
Postby andz327 » Thu Nov 16, 2017 7:49 pm
[quote="F111ORY"]Just bumping this back to the top as I seem to be suffering from invisible man syndrome!
WHO SAID THAT
andz327
Postby knobby1 » Thu Nov 16, 2017 10:04 pm
andz327 wrote:WHO SAID THAT
Who said what..?? :? :shock: :?: :wink:
Postby andz327 » Thu Nov 16, 2017 10:29 pm
If a did nea know better I'd have said there's somebody aboot
andz327
