by Rig » Thu Nov 16, 2017 3:01 pm
You might have solved this issue by now, but I have the same problem. My issue is that the back battery clamp isn't a tight fit anymore, I've tightened it as far as it'll go but it's worn out, it's just that, that needs replacing and it sometimes loses it's connection for a moment. If it isn't that exact issue I've definitely search around the battery connectors and make they have very tight fits.
2006 MK7 High Top LWB RWD - currently converting into a campervan
