di tappets
di tappets
Postby scas » Fri Nov 17, 2017 5:17 pm
2.4 di. im getting a popping again from my airbox,which i know is the hydraulic tappets. can the tappets be pulled apart and fixed-rather than buying secondhand ones
06 mk6 2.4 di 115 remapped by martyn
04 mk6 2.4 di 115 remapped by martyn
04 mk6 2.4 di 90
05 mk6 2.4 di 115
new 06 mk6 2.4 di 115
new 00 mk6 2.4 di 125
can you see a pattern
scas
Re: di tappets
Postby kennyb11 » Sun Nov 19, 2017 4:41 pm
ive just changed all the rockers on my 2.4di due to same problem ,did make engine run quieter but still have the thumping noise through resonator,also just rebuilt head and checked all pistons before new head went on,all good.so dont be surprised if noise is still there after changing rockers
kennyb11
Re: di tappets
Postby scas » Tue Nov 21, 2017 6:01 pm
kennyb11 wrote:ive just changed all the rockers on my 2.4di due to same problem ,did make engine run quieter but still have the thumping noise through resonator,also just rebuilt head and checked all pistons before new head went on,all <span class="skimlinks-unlinked">good.so</span> dont be surprised if noise is still there after changing rockers
did you use new tappets or secondhand?
i had an awful thumping six months ago and when i took out the tappets i think about 6 were seized-it was about 6,cant remember. so i stuck in ones from my feked,bottom end, engine and it cured the thumping instantly.
04 mk6 2.4 di 90
05 mk6 2.4 di 115
scas
Re: di tappets
Postby kennyb11 » Fri Nov 24, 2017 7:45 pm
all new as old ones were gubbed ,my mate suggested a stuck valve but I checked springs and valves while head was off ,all good.van drives fine plenty of power no smoke but noise is still a mystery
kennyb11
Re: di tappets
Postby scas » Sat Dec 02, 2017 12:30 pm
do the tappets just pull out of the arm? and are they meant to be hard or with a bit of give in them when new?
04 mk6 2.4 di 90
05 mk6 2.4 di 115
scas
Re: di tappets
Postby kennyb11 » Sun Dec 03, 2017 3:22 pm
I bought a set online £109 for the lot,you should be able to push the spring in and it should return itself,all of mine were solid that's why I replaced them all, not sure if you can free them up
kennyb11
Users browsing this forum: M3Stig, Majestic-12 [Bot]
