Noise from gearbox goes away when clutch depressed
Postby Morwellham » Sun Nov 19, 2017 8:36 pm
Hi All,
I am looking at a 2010 Transit 350 AWD and it has a gearbox rattle when the clutch is up. Press the clutch pedal and it goes away, thinking it maybe the release bearing or the gearbox idle shaft. Any ideas??.
Naturally, I am concerned about a idle shaft issue.
Also, any pointers as to what are the things to look for on a AWD transit.
Thanks in advance.
Andy
Morwellham
Re: Noise from gearbox goes away when clutch depressed
Postby Pigwag » Sun Nov 19, 2017 10:35 pm
Usually a thrust bearing. When is under pressure, no noise.
Pigwag
Postby Thequeenscheese » Mon Nov 20, 2017 12:00 am
Pigwag wrote:Usually a thrust bearing. When is under pressure, no noise.
This, or maybe pressure plate, either way box off so may as well swap clutch, bearing, plate the lot..
2.2 tdci T280
Thequeenscheese
Postby bambi mk 1 » Mon Nov 20, 2017 12:05 am
Flywheel :wink:
bambi mk 1
Postby karl » Wed Nov 22, 2017 8:35 pm
bambi mk 1 wrote:Flywheel :wink:
but not all fwd or rwd had dual mass put in on the production line
karl
Tranny Lover!!!
Postby knobby1 » Wed Nov 22, 2017 8:58 pm
I think he has an "AWD" 6 speed machine....they "should" be dual mass from the factory....but there is an option for single mass in the parts list.
Postby karl » Wed Nov 22, 2017 9:01 pm
ok :D
karl
Tranny Lover!!!
