jumbo 57 wrote:Ok, decided it was time to attack prior to the part arriving Wed,
I've got a 2 poster so I decided I needed to get it up in the air and go in from below,
20 minutes later and I've removed the starter motor and oil filter housing.
Looks like I need to remove at least 2 injector pipes, and I need to make a special socket, grinder and old socket should do.
Tune in tomorrow for another exciting episode,
Will the van slip off the hoist?
Will I be able to get rid of the diesel taste?
Is the biscuit situation really that good?
Should I have liberally sprayed the solenoid with WD40 before packing up for the night?
chris72a wrote:jumbo 57 wrote:Ok, decided it was time to attack prior to the part arriving Wed,
add to that,
will I lose a finger in the process ( Feckin hope not!!)
will I end up having to remove the entire pump (Really feckin hope not, I don't think I have 3 equal sized drill bitz to my name!! )
will I win the world record for the most amount of swearing in a day (Probably )
will I complete the job and realise I forgot a bolt and had to take it all apart again (I didn't amass a fine collection of nutz n bolts by doing things right!! )
I do hope you have better luck than I did you have a hoist so thats a much better start than trying to do it with one side jacked up!
Looking forward to the next instalment
Cheers
Chris.
ned wrote:Your supposed to wedge the cigarette between the ch__ks of your a__e
jumbo 57 wrote:Out of interest,
Is there a way to test the old solenoid now that I have it out hanging on it's wires
jumbo 57 wrote:The funny part was disconnecting the coolant hoses from the oil cooler, the water ran down the raised arm and out the lower one, it extinguished my newly lit cigarette!!
Good job it wasn't petrol!
Users browsing this forum: Google Adsense [Bot], metalworker0
