Did i drain to much from the diesel filter?
Postby MontorL » Sun Nov 19, 2017 11:24 pm
Hello!
Got the light that indicates water in diesel filter followed by the powertrain light. Pullet over to drain. drained maybe one liter.. 2 mins after driving i got the powertrain and the engine light. What have i done? :roll:
Its a 2012 125T300.
MontorL
Re: Did i drain to much from the diesel filter?
Postby mjsroofing » Mon Nov 20, 2017 9:46 am
You'll need to get it plugged in to read codes.
www.mjsroofing.co.uk
2009 2.2 tdci 115ps just over 51k and sweet as a nut ( so far )
2002 2.0 tddi 100ps. Over 205k still sweet . Now owned by Jay.
2001 escort van 75, 1.8 turbo intercooler. scrapyard heaven
1995 escort van 50, 1.8 straight diesel, scrapyard heaven.
mjsroofing
Postby MontorL » Mon Nov 20, 2017 10:34 pm
Ok. Did that today.
I bought the car last friday. After driving for 5 minutes the "water in fuel" light came on. I called a guy with some Transit knowledge and he told me about the drain valve on the fuel filter. I pulled over an drained some. The light went away and i drove 650 km home. No lights on the trip.
After 20 km driving in my town the Drivetrain light came on. Followed by the water in fuel light. I stopped and drained some more. Maybe 0,5 liter.
After that, only the Drivetrain light came on after 2 min. Followed by the Check Engine light.
Today i brought the car to the Ford dealer and on the sheet it says:
Connect to IDS, Read off, error codes in FordE-tis IDS, enter symptoms, send session files, change to IDS standard.
Error Code: P2539-PCM Low Pressure Sensor In The Fuel System, Circuit
Deleted error codes and test drive - OK
5 mins after i drove off, the Drivetrain light came on, stopped and started the engine, light came on again, followed by the Check Engine light, followed by the Water in fuel light.
Im taking the car back to the Ford dealer tomorrow.
Does this sound familiar to anyone? Any clue?
Have i managed to get air in the system by opening the drain valve to much?
Many thanks..
MontorL
Postby knobby1 » Tue Nov 21, 2017 12:27 am
MontorL wrote:Ok. Did that today.
Many thanks..
Is this a Euro 5 machine..??
Postby MontorL » Tue Nov 21, 2017 12:48 am
How can i figure that out?
MontorL
Postby MontorL » Tue Nov 21, 2017 12:52 am
FORD TRANSIT FAA6 (VII) 4WD Diesel
CYRB 2.2 TDCI
MontorL
Postby knobby1 » Tue Nov 21, 2017 1:03 am
MontorL wrote:How can i figure that out?
The Euro-4 machines never had a 2.2 125 PS engine. Is the engine badge on the left rear door blue or red..??
Postby MontorL » Wed Nov 22, 2017 12:54 am
Euro 5 yes. The Ford dealer changed diesel filter and cleaned a sensor on the fuel rail i think today. And i disconnected the battery for a couple of minutes with no result. The Drivetrain lamp still comes on.
Its a tricky one this..
MontorL
Postby ake » Wed Nov 22, 2017 8:08 am
MontorL wrote:Euro 5 yes. The Ford dealer changed diesel filter and cleaned a sensor on the fuel rail i think today. And i disconnected the battery for a couple of minutes with no result. The Drivetrain lamp still comes on.
Read codes again
Postby karl » Wed Nov 22, 2017 8:24 pm
the cog light ?
when you change fuel filter on these you have to prime the filter using for ids :( then reset the counters
karl
Tranny Lover!!!
Re: Did i drain to much from the diesel filter? Solved (sens
Postby MontorL » Fri Nov 24, 2017 12:16 am
Problem solved. They changed the sensor that they cleaned. Dont know which sensor yet as i haven't got the report.
Many thanks for the input.
MontorL
