Hi guys, New to here
Not sure if anybody can shed some light on things,
Transit 2006 mk7 2.2tdci 130bhp.
Vehicle has been loosing power when giving it some gas and intermittently going into limp mode when putting foot down.
Fault code P037D glow plug relay sense circuit
P2265 water in fuel sensor circuit range/performance
P062B internal control module fuel injector
cleaned up and fitted new injector copper seals as 2 were leaking
Have a glow plug tip stuck in no1 cylinder that I know. But all wiring attached to glow plugs
New EGR and turbo fitted about 12 months ago but fault has been ongoing since then
Had EGR delete which made no difference
recycle the ignition and vehicle goes fine until I give the right foot a press.Any ideas guys? TIA
