Liamelliott wrote:Ok guys so I’ve got the egr off and it seems quite dirty considering the bloke I brought it from said it was new.. so I’m gonna clean it up and try that, if problem persists I might try a new egr.. I noticed on the side of the egr there is a hole where it looks like something should be connected not sure if this is right or not
Also got talking to a neighbour who suggested taking off the inlet manifold so I did and it is caked in shite about 3-4mm thick and big mounds of it further in.. also where the inlet joins the engine is there any way I can clean the soot in there? Does it matter too much if the soot falls in the engine.. thanks guys
loot wrote:If the egr is causing the smoke then it will have a fault that will be obvious if you open it up, the pins on the gear can snap and the grub can pop out, this is the only instance where the valve is blowing by that will cause terrible running and smoke.
If you are suffering quite badly then there is a leak here or maybe damage in the pipes or intercooler.
