Speed limit remove Somerset?
Postby dhoyles » Tue Nov 21, 2017 4:14 am
2010 mk7 ex British Gas ?
dhoyles
Re: Speed limit remove Somerset?
Postby dhoyles » Tue Nov 21, 2017 11:05 pm
[quote="dhoyles"]2010 mk7 ex British Gas ?
Bristol, Exeter? Anybody sort this out for me please?
dhoyles
Speed limit remove
Postby dhoyles » Wed Nov 22, 2017 4:43 pm
2010 ex British Gas
Any help with this much appreciated
I’m in Somerset so Bristol Exeter many thanks
dhoyles
Postby Jim Archer » Wed Nov 22, 2017 8:25 pm
I think you need IDS, but don't quote me.
Ford service is the obvious answer.
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
Postby karl » Wed Nov 22, 2017 8:29 pm
dhoyles wrote:2010 ex British Gas
ids will not remove speed limiter from these you have to get a remapper todo it or a believe another calibration file then try again but I have been unsuccessful doing this :(
its like it locked to the pcm
karl
Tranny Lover!!!
Postby knobby1 » Wed Nov 22, 2017 8:49 pm
I've changed mine (2008 Mk7) several times Karl....On mine there's three options, 1: None 2: 100kmh (~60mph) 3: 120kmh (~75mph). Both IDS & Forscan can do it..
Postby karl » Wed Nov 22, 2017 9:07 pm
I know but with these being fleet vans over here in the uk they lock them at the factory I have tried doing them with my ids v86.04
I even tried a ex royal mail van and was the same on that :(
karl
Tranny Lover!!!
Postby knobby1 » Wed Nov 22, 2017 9:36 pm
karl wrote:I know but with these being fleet vans over here in the uk they lock them at the factory I have tried doing them with my ids v86.04 I even tried a ex royal mail van and was the same on that :(
Ah....didn't know that..! Learn summink new every day..! :oops: :wink:
Postby mjsroofing » Thu Nov 23, 2017 8:13 am
I did one over here, not sure what van it was before I took limiter off.
Standard white van it was 08 plate.
Same as what knobby wrote.
www.mjsroofing.co.uk
2009 2.2 tdci 115ps just over 51k and sweet as a nut ( so far )
2002 2.0 tddi 100ps. Over 205k still sweet . Now owned by Jay.
2001 escort van 75, 1.8 turbo intercooler. scrapyard heaven
1995 escort van 50, 1.8 straight diesel, scrapyard heaven.
mjsroofing
Postby ake » Fri Nov 24, 2017 7:30 am
British Gas vans have the limiter built into the pcm map, they can’t be removed by the usual methods, you need someone like vantuner to install an unlimited map for you
Postby karl » Fri Nov 24, 2017 4:33 pm
ake wrote:British Gas vans have the limiter built into the pcm map, they can’t be removed by the usual methods, you need someone like vantuner to install an unlimited map for you
royal mail are the same :(
karl
Tranny Lover!!!
Postby paul2012 » Mon Nov 27, 2017 5:52 pm
On mk7's Speed limiter is set in BCMII configuration :wink:
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
