2010 mk7 ex British Gas ?
dhoyles wrote:2010 ex British Gas
Any help with this much appreciated
I’m in Somerset so Bristol Exeter many thanks
karl wrote:dhoyles wrote:2010 ex British Gas
ids will not remove speed limiter from these you have to get a remapper todo it or a believe another calibration file then try again but I have been unsuccessful doing this
its like it locked to the pcm
knobby1 wrote:karl wrote:dhoyles wrote:2010 ex British Gas
I've changed mine (2008 Mk7) several times Karl....On mine there's three options, 1: None 2: 100kmh (~60mph) 3: 120kmh (~75mph). Both IDS & Forscan can do it..
karl wrote:I know but with these being fleet vans over here in the uk they lock them at the factory I have tried doing them with my ids v86.04 I even tried a ex royal mail van and was the same on that
ake wrote:British Gas vans have the limiter built into the pcm map, they can’t be removed by the usual methods, you need someone like vantuner to install an unlimited map for you
