birdie wrote:Mine was a little stiff.
ned wrote:No need to be rude is there
Squirell2212 wrote:ned wrote:No need to be rude is there
Agreed! , hopefully someone turns the van over before the locks fitted , a good bit of karma
Steve192 wrote:Squirell2212 wrote:ned wrote:No need to be rude is there
Well if they get through this pal, then karma is a bitch
Steve192 wrote:Only simple when the lock isn’t playing up. Had to drill it out so the “simple” method didn’t work. As you were
