Hi Everyone.
I have a 2002 2.0 TDDI 75hp transit 100,000 miles. We bought it about 8 months ago and it has been brilliant until last Friday. On the journey home from our nearest town (Elgin) it started to sound a bit more clattery than normal. I could hear something wasn't right before my mrs or son did. It was also a bit down on power. Over the rest of the journey (23miles) it got a bit rougher and more gutless. I was debating stopping but decided to just get home as it was dark and raining. By the time we got home there was a real diesel knock sound which has never been there before.
The following morning I had a good look in daylight but couldn't see anything obvious. I started it again and sounded like a tank, really loud diesel knock at tickover but at about 2000 rpm (complete guess), with just a whiff of throttle) it quietens down. My first thought was injector but there is no smoke at all. A few years ago I had an 03 TDCI mondeo and when an injector went on that it smoked like a steam train.
We moved to the area a year ago so I don't really have any experience of local garages. I phoned a few places and plumped for a small back street garage that had a good review on Google. They've had it a week. Initially he said it would either be timing has slipped or egr valve as there would be smoke if injector problem. Yesterday he checked the timing which he said was spot on. He now thinks it's a faulty injector but can't test them so he said it needs all four as if you only change one it will run terribly. He quoted £120 for each injector plus fitting. On my mondeo I only changed one and it ran ok.
He also says the injectors are mechanical and you just screw them in with no programming etc required.
Is he right about changing all four? Can they be tested? If they are a simple fit could I just buy one myself and through trial and error, swap them about until it runs better? Can I simply remove the fuel pipes on the top of the engine without them leaking when I refit them. Would they need replacing?
Can anyone recommend a good diesel specialist in Elgin area (north east scotland).
I told the garage I would think about it over the weekend and call them monday. I cannot afford a big bill.
Thanks for any advice
Rich
