by mnxtrany » Tue Nov 28, 2017 12:01 am
The Dutch Guy.
a multimeter cannot "break" a electronic system, especially not a rubust automotive computer.
usually these issues come from crappy connections. most lights are negative switched, so the light always has power and a dodgy wire somewere can leak to ground enough to pull power but not light the bulb.
I was informed that the use of a multimeter on modern electronics - signalled - could damage the electronics. It happened to a fella with a van who had taken out and put back in the battery = things didn't work. He used a multimeter and knackered the van electronics.
I havn't done much electrical work on the my 17 yr old van except to add to it. I put the switches on the positive side. Long time ago the power/switch was on the positive - safer - . I apologise if I got things wrong.
Thanks for the info'.
I'll have to have a look sometime.
Ford Transit, 3.5, Mk6, 2.4 (90PS) 88.76 HP 66.19 KW Duratorq DI diesel, 2000 Luton back, Tail lift, MWB, DRWD.
