Is the CKS on the head high up near cylinder #4?ned wrote:The cps is on top/side of gearbox above the flywheel easy to get to from under the van, well mine is anyway. N
Speed sensor yes. Then right on the selector mechanism theres the reverse lamp switch.White2Blue wrote:I have it up on axle stands only on the first setting, I think I may need to get it higher...
I did find a cable going to (presumably) a sensor on a part of the transmission which is in line with the driveshaft, but that's too far back I assume as it's not on top of the flywheel! Probably a speed sensor?
martynx wrote:Is the CKS on the head high up near cylinder #4?ned wrote:The cps is on top/side of gearbox above the flywheel easy to get to from under the van, well mine is anyway. N
bambi mk 1 wrote:ned wrote:The cps is on top/side of gearbox above the flywheel easy to get to from under the van, well mine is anyway. N[/quote ]Dats cause you are always under it Ned
ned wrote:martynx wrote:Is the CKS on the head high up near cylinder #4?ned wrote:The cps is on top/side of gearbox above the flywheel easy to get to from under the van, well mine is anyway. N
What's the cks (cam knock sensor)? I thought the op was looking for the crank position sensor N
White2Blue wrote:ned wrote:Is the CKS on the head high up near cylinder #4?martynx wrote:[quote="ned"]The cps is on top/side of gearbox above the flywheel easy to get to from under the van, well mine is anyway. N
