White2Blue wrote:Yea drives lovely, first few hard accelerations produced some smoke but thats mostly gone, much quicker than the other van...but it is empty! I’m hoping the dripping was the excess from bleeding the system...
Gearbox, clutch all feel good : ) I’ll be stripping the gear actuator thing and cables off the old one as they weren’t long fitted.
The last owner really took good care of it. No dents on the bodywork, 46k on the clock, interior and the back are mint!
Yea I did the metering solenoid on the older now fitted pump, if I remember the crimps didn’t work well so I soldered them!!! That was before I knew the damage it could have caused to the ecu!, heat sheild is on just decided to put crappy insulation tape on it : )
Does anyone know if there’s a way to find out if the internals of the pump that came off are knackered? I emptied the filter and it only had a few specs of stuff in and the injectors must be fine so it can’t have broken up much... I wondered if the guy who fitted the ‘repaired’ecu back on the original pump had connected the wires incorrectly...
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot]
