Hi all,
I'm having a real nightmare with this van. At times it runs great without issue and then there's times where the van begins to kangaroo and judder like crazy on very light throttle, typically around the 1500rpm range. You have to fully let up on the pedal to stabilise it again. No codes are showing.
I've changed the scv and done the pump relearn, injector pilot and prv counter reset.
I've seen a couple of posts on similar symptoms but with no solution.
Any ideas? It's a 2011 mk7 2.2 (85)
