The biggest problem for me is technical English - each text requires a lot of work, and I don't know if I am writing it clearly. Also, the original texts on the Forum are not always understandable to me, the colloquial language is used, not the school one. I've never been to GB.
To the point: in your first post you wrote:
"Have read posts and checked the solenoid valve in engine bay next to coolant pipes on firewall. It does pull in when engine running . " This means that the valve is operational. This valve works so that when it is closed, hot fluid returns to the engine — only the two hoses to the valve are hot. But when it is open, all four hoses are hot, two very, two return less. So: if you disconnect the vacum hose from the valve actuator, the valve will be open and the heater will be hot while the engine is running.
Therefore, unfortunately I do not understand what you are writing:
"Story now is I discon. The suction hose ( engine on and it was sucking ) blocked the hose. Heater controls set. No change inside cab . Both coolant pipes going to valve in n engine bay were hot ."Next: this water valve is controlled by a vacu solenoid valve. It is activated by a switch in the heater by means of a rotating flap shaft. And this shaft is moved by an electric actuator, which is positioned by a knob on the control panel. Positioning is performed using an electric bridge with potentiometers. This electric motor is the most common cause of the lack of heating.
There are mainly three reasons for its failure:
- failure of the motor (brushes)
- wear of the intermediate gear cog (quick repair is possible without changing the gear)
- potentiometer damage (no contact - sometimes new grease helps and moving the slider to a new location)
You have a lot of threads on the forum about how to repair an electric motor. I described in the past that you can buy a used electric motor from the old Mondeo Mk2, there are almost the same and critical parts are spare. To end this long fairy tale: if you manage to disconnect the water valve from the vacu hose, the heater will definitely be hot. The question is, in what position did the electric flap actuator stop. If it is completely cold, the heating will be weak. In this case, you can also manually set the flaps to heating without repairing the electric actuator, but you have to remove its cover and set the flaps properlyr.
But that's a completely different story ...
Removing the actuator and reassembling it is extremely unpleasant and requires nerves of steel.
viewtopic.php?f=5&t=125180&p=1334470&hilit=heater+actuator&c=1#p1334470viewtopic.php?f=5&t=201040&p=1696871&hilit=heater+actuator&c=1#p1696871viewtopic.php?f=5&t=201040&hilit=heater+actuator&c=1viewtopic.php?f=5&t=165848&p=1409124&hilit=heater+actuator&c=1#p1409124
